MK3 Cav water leak in boot
Noticed when clearing it out boot carpet on O/S was damp, i know drain issues have allways been about on cavs, but any idea of where to look for this, wasnt soaking, but wet enough to worry about
cheers
it's the rubber hose by the rear lights (one each side) that has come out of its rubber bung in the boot floor. Stick it back in.
It drains the sunroof.
Very very rare for a cav boot to be wet for any other reason.
cheers Giles
havent looked at the car yet, but where abouts does this hose run ? have to removed the rear trim to get to it ?
Mine had a "trough" where the water could collect, the level would rise and spill into the boot.
It was in a direct line under the electric aerial on mine, might be the same on the O/S too.
I drilled a couple of holes and the water poured out, never did have the problem after that.
