Has anyone used BR4 High gloss lacquer before?? Went on well and with a 'high gloss' but I have flattened it down as there was some orange peal, but now it's dull even after polishing it a few timesAny ideas??
Never heard of it,
When you painted it was it cold?
Is it in date?
what did you use to polish it?
Used G3 with lot's of water, then autoglym super resin polish, have used this combo loads before with good results. It's anoying as it was really shiny before. Lacquer is new, and garage was heated when sprayed.
Try a bit of g6,
It might just want polishing up more..
Can go misty from the cold, But if you've had it heated then its not a prob,
