Fittin rear panel 2 back of mk3 astra
Results 1 to 7 of 7
Thread: Fittin rear panel 2 back of mk3 astra
    Sep 2001
    hereford
    Vec SRi V6
    right i should have a GSi rear panel 2 fit 2 the back of my mk3 astra an i got a few queries
    1. Do i just remove the handle round the lock??
    2. Will it be possible just 2 bond it on??
    3. If so wats best 2 use??
    4. Do the existin number plate holes line up with the panel??
    5. Is anything else needed that i havn't 4 seen??
    thx in advance
    Blippi
    aka Darren
    Somerset
    2006 Suzuki GSXR 750
    Hi Darren,
    Yes, remove the handle on the tailgate. Do this by removing the inner tailgate trim and undoing the (I think) 2 nuts.
    You can bond the panel on, and I would think silkoflex will probably be the best to use. However, bolting it on will allow you to remove it, wheareas once its bonded on, it aint coming off, easily anyway.
    I would imagine numberplate holes match up, wouldnt know as mine is stuck on instead of bolted on.
    You will also need the black round lock surround for the rear tailgate panel. These are pennies.
    H2H
    Adam
    -VXRacing-
    12.1 @ 123mph 1/4 Mile
    Sep 2001
    hereford
    Vec SRi V6
    thx m8 think u've covered it i'll give ya a shout if i have any probs
    May 2001
    South East
    The panel uses clips to attatch the the tail gate, which in turn are bolted/screwed to the tailgate, so your best/easiest option is to bond it on.
    Yep, handle is just two bolts hidden behind the interior trim.
    1. Remove interior trim
    2. Undo two bolts
    3. Remove handle
    4. Clean tailgate and prepare surface for bonding
    5. Attach panel
    6. Buy the little trim which push-fits over the lock barrel
    7. Sit back and admire.
    OllyHewitt
    Guest
    done it yet mate?
    Somerset
    He doesnt have the panel yet.
    He should have it by beginning of next week
    -VXRacing-
    Sep 2001
    hereford
    Vec SRi V6
    oh yes lmao
