-60mm springs for a GSI
Hi,
Do any companies make -60mm springs for the Nova Gsi?
All I can see advertised is -40mm or -35mm or -60mm for the lesser models.
Cheers
Miles
hi miles, impreety sure all the nova springs are compatable with all novas ie 1.2 with 1.6 gte.
await confirmation though.
Hi,
What I mean is that because the Gsi/GTE/Sri are lower than the base models as standard I want some specific -60mm Gsi/GTE/Sri springs so it is well low!
If you look at the part numbers in some adverts they give -60mm for base models and then the same part number but with a -40mm for the top spec motors.
But thanks anyway Lee, my poor explaination!
my mate has -60mm kit on his gsi it is a jamex kit and he is taking the springs off and putting on -40mm as the 60mm is way to low it is catching the front arches and a total ball ache on our roads
