Cav Side Skrts on Nova Saloon?
Results 1 to 4 of 4
Thread: Cav Side Skrts on Nova Saloon?
    Lincolnshire
    Nova IT's 4 SALE!!!
    Do they fit? How are the little white clips on the sill held on?
    Ross
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    I take it you mean SRi skirts, they may be a bit long but if you know someone who`s good with plastic they shouldn`t be to hard to fit.
    I`m not sure how the clips attach but an alternative would be to have them bonded (glued) on. I mate did this to fit GSi skirts on my Cav. It`ll also make it easier if you have to modify the skirt (cut a bit out) as you won`t have to worry about lining the clips up.
    R Joy
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
    Oct 2000
    Portishead
    300ZX TT & Passat R
    The clips are held in with special rivets. But I wouldn't recomend fitting these on your Nova. Everything will have a different contour compared to a Cav, so you'll find that they won't serve their purpose.
    wales
    vauxhall nova
    i thought the only purpose of a skirt was to look good!
