Mk1 Astra Seats into Mk3
Does anyone know if I can get a set of subframes to convert Mk1 GTE seats into a Mk3 Car?
Re: Mk1 Astra Seats into Mk3
Originally posted by MP5SD Does anyone know if I can get a set of subframes to convert Mk1 GTE seats into a Mk3 Car? If its going into MK3 Astra then wont need to swop frames - should bolt straight in.
Dont mean to sound rude but can anybody else confirm this as the frames look different.
Originally posted by MP5SD Dont mean to sound rude but can anybody else confirm this as the frames look different. If the frames are definately different then would just need to swop them over.....ie Mk3 Subframe to MK1 Seat....
Ive put them in a MK2 Astra in the past and they fitted straight in .... thought the MK3 was just a rounded off MK2 *
I will have to get the both side by side and see what I can do with them. May just get the trusty welder out and do an A-Team on it.
