Will that look alright on a mk4 astra?
I have found some sweet rally wheels but they are only made in 15" same as the WRC regulations
Does anyone have their car lowered 60mm running 15s that is a simmilar size to an astra G?
Very subjective question TBH.
Some people think huge bodykits look OK, others think they look gash. It's all personal choice. I personally think they would look too small on a Mk4 but others may think it would look 'Euro' etc
Welcome to MIG BTW!
Warren Buffett.
agreed, even the standard 16's on the sri look too small.
If you are gonna spend money on wheels then its got to be 17's minimum imho
Thanks
With the sandard 15s or whatever it has with the factory suspension, when I have a full load (4 peeps and a full bootload) it drops quite a bit
So if I have it lowered 60mm it will still go lower with a full load and if I have the 17s it could well rub which I do not want
Are there any pics of 60mm lowered cars?
If the offset of the 17 inch rims are right it wont rub
What offset should I be looking for?
On a car the size of a mk4 astra id definently go bigger than 15s.
16s minimum.
