Results 1 to 3 of 3
Thread: Harness fitting
    May 2006
    St Awful
    Cally T & Astravan
    Harness fitting
    Right i have a pair of Sabelt harnesses that i want to fit into my Cally, i have figured where the shoulder straps are going and where one lap strap is going to be fixed but where can i fix the other lap strap that goes towards the transmission tunnel?
    These are to be used daily not now and again. So i want it to be safe.
    MIGWeb User andrew_lumb's Avatar
    Apr 2004
    Huddersfield
    Skoda Octavia vRS
    i welded a 2mm plate to the vertical part of the tunnel, and bolted an eyelet bolt through.
    did the same on the inner sill the other side.
    May 2006
    St Awful
    Cally T & Astravan
    Thanks for that. Have seen some plates on ebay that would probably do it.
