16in rims
how can i get these to fiton a 60mm drop on a corsa
They will fit with some proper fitment wheels, right offset.
the wheels are of a nova thats all i no if i have to grind the archs im guessin its best to take the plastic arch of and grind the metal and put the plastic one back on
Have you tried them on?
If they came off a nova, chances are they should fit your corsa fine(as its harder fit 16s to a nova than it is to a corsa)
