astra cab
is there any one who has seen a boot install for astra cab got 3 amps two subs mids and tweeters to go in just try to figger out when to put amps with out tacking all off the floor . Has any one ever put amp on back self or does the roof come down to far havent looked yet my self wheather to ****
I bolted an autochanger to the underside of the rear shelf in my old Cabby. Take out the rear trim/carpet along the shelf where the hood would retract. Mark out where you want the amp to sit. Drill holes down inside, mount underneath (boot area) refit trim and all done.
