sikaflex ??
Results 1 to 14 of 14
Thread: sikaflex ??
    Dec 2001
    perth, w. australia
    cavsri16v, holden
    sikaflex ??
    i have cut a rear bumper of a peugeot 406 up to fit on the back of my belmont bumper and need to bond it together. would sikaflex be up to the job or am i better finding something else. it is two plastic surfaces being joined so is it any good for that.
    can anyone give any pointers to where i can get it from or a phone number for them.
    many thanx.
    Apr 2002
    County Durham
    a car
    Any shelf gen?
    ste'
    Jun 2001
    Hereford
    R33 Skyline
    i dont know about sikaflex, but if it was me i would screw/bolt the two parts together as well to add strength, and take some of the load of the bondant.
    I am sure someone will say otherwise, but it cant hurt.
    Dec 2001
    perth, w. australia
    cavsri16v, holden
    i've put a couple of self tapping screws in at the mo just to line it all up, but didn't really want to leave them on as they don't look right, hence the sikaflex question. any other suggestions?
    Berkshire
    BMW Beauty
    put them two together, then put a fibreglass skin over the whole thing... make it smooother too, and look as one.
    its a suggestion!
    Jan 2002
    southampton
    Astra 1.6 16v sport
    i work with sikaflex everyday m8 and believe me m8 when i say it is WICKED it will stick anything and still stay plyable (rubbery)
    omly thing is if you want to take it off in the future forget it unless you are prepaired for the use of a sander and a lot of swearing
    if freedom is outlawed, only outlaws will have freedom
    Aug 2000
    Paisley,Glasgow
    Astra 1.6 16V,A
    I would screw the two bumpers together from behind then sikaflex round the edges and then fibreglass resin all joins and sand down.Its the only way to do the job right and you can still take it off etc later.Remember to screw from the back and when its all solid take the screws out,if you do it from the front the fiberglass may react with the screw heads!
    Good luck
    Aug 2001
    Swindon, Wiltshire
    Astra 3/Corsa C/Cav
    wont the fibre glass crack?
    ive got a similar project on the go - and ive been adivised to plastic weld them 2gether, rather than use fibreglass
    PhilAstra@Hotmail.com
    Aug 2000
    Paisley,Glasgow
    Astra 1.6 16V,A
    no not if you use fibreglass resin,and lots of it.did you see the flippy calibra with the cosworth whale tail that body kit is constructed of entirely fibreglass as long as you set it properly you will have no problems,trust me
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Andy fibreglass will crack, what you have to ensure is you get the right mixture of resin and harnderner.
    Mix the resin and hardener to the right consitancey and then brush it on the fibreglass and you should/might be ok.
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    Aug 2001
    Nr Bath
    GTE. Rebuilds:Kadett
    Where do you get sikaflex from?
    Aug 2001
    Swindon, Wiltshire
    Astra 3/Corsa C/Cav
    i just got some from partco
    Aug 2000
    Paisley,Glasgow
    Astra 1.6 16V,A
    Scott you were with me when we were talking to the guy who constructed his whole bodykit from fibreglass,remember the guy with the calibra,it wont crack
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Yeah i remember but what your saying could be misleading, its not just the resin in the mixture of the resin/hardener/ matting that means it wont crack.
