will cav gsi bumpers fit straight on to a cav mk3 hatch or do u have to drill extra holes or even modify it please help .
front one should be no be problems
rear oen may be too long in the side bits
tom
so will all the holes be in the same place so its just a case of bolting it on?
The front goes straight on ( I`ve put one on my cav ) but the rear is a couple inchs longer & I don`t think the mounts line up but with some cutting & filling I`m sure it could be made to fit..
If you do manage to get the rear on let me know as I be interesed to know how you did it.
R Joy
3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
Best way to get the rear on would be to remove the apron (body coloured part) fron the actual bumper (black part) and then modify it to fit the bumper on your hatch - the just a case of cut and shut on the apron and you don't have to worry about bumper mountings. HTH.
