MK3 astra dash help
Hi i was wondering if anyone with the mk3 dash tried to get the centre console off.The one with the heater controls.I seem to have every screw i can find off,is there some behind the display above the head unit?
How do you get the display out?
pull out the little rubber mat just below the display, then there are some screws that you need to remove.
there also screws located around the steering column and the dial surround needs to come off too
