Does Anyone Have A Mk2 Cab And Mk2 Astra On There Path?
Results 1 to 7 of 7
Thread: Does Anyone Have A Mk2 Cab And Mk2 Astra On There Path?
    May 2002
    liverpool
    Zafira VXR STAGE 2
    OK SO I NEED TO MATCH THESE TWO CARS UP SO THAT I CAN SEE IF THE ASTRA KIT WILL FIT THE CONVERTABLE:http://www.ccmotorsport.co.uk/vauxha...stra-body2.htm HERES THE KIT
    APPRECIATED GARETH.
    Im a Daddy Wahoooo
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Gareth, the wheelbase and overhang dimensions are the same for both the MK2 hard top and soft top.
    The kit will fit no problem. Everything below the top swage line is the same and as this is where the kit fits, you'll have no problems.
    The differences are internal. Bigger sills, but these encroach on the interior space, not the exterior. You won't obviously be able to fit the rear spoiler.
    The door dimensions are the same with just no rear pillars.
    May 2002
    liverpool
    Zafira VXR STAGE 2
    thanx alot mr parson's just what i wanted to hear... absolute god send...what u think of the kit im after? apprecaited
    Im a Daddy Wahoooo
    Oct 2000
    Portishead
    300ZX TT & Passat R
    The kit looks good, just why the hell didn't they stick some wide as hell wheels on it?????
    Reckon it would look great on a MK2 cabby. Just make sure you get wheel spacers or wide as hell wheels for it. Will look the mutt's nutts then!
    May 2002
    liverpool
    Zafira VXR STAGE 2
    just what i was thinking matey....im happy now!!!!cant fitting spacers wreck bearing's?... the v6 project aint coming fast enough!!!damn solicitiors......been told cc is a bit moody though where else do u wreckon might do the kit mate?
    Im a Daddy Wahoooo
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Not sure. just get ome with a crazy offset. Will look better. You may find that bearings wear out quicker, but they are cheap and easy to do. Better that than biscuit wheels.
    Spray car a nice electric blue. V6 do it! Tis what I want!! NOW!!
    Try PMC for the kit.
    May 2002
    liverpool
    Zafira VXR STAGE 2
    u got pmc's mail address mate?
    Im a Daddy Wahoooo
