do a few hand brake turns on a tarmac surface whilst the bolts are loose but on.
or curb it by swinging the back with hand brake turns
got it off with a bit of WD40, a big hammer and lots of swearing...now i just n eed to change my bearings lmao
EDIT - thanks for all the help guys...especially MSG's lmao
Jeeesus!
just ****ing hit it with a block of wood on it, HARD!
Bloody mincer.
Originally Posted by wayne451
use a plank of wood from behind and slam em
when i replyed to ur thread i didnt read next page!
lmao
but yeah slam that homerun woohooO!
Is the wheel still on?
yeah wheres the pics mince boy?
you suck.
Grim, be a bit careful with the WD40 as you don't want to get it on the brakes. If you go carefully I'd recommend a trolley jack a big hammer and some wheel chocks of some sort. Jack the car up, put axle stands under it (and don`t even think about not using them mate) and chock the front wheels. Carefully spray some penetrating oil around where the wheel goes on to the hub and gently release the handbrake and gives the wheels a good old fashioned tw*tting from behind with the lump hammer. Withe the handbrake off you can move the wheels around so you can hit them from different places. Once off give the bit where the wheel centres sit onto the hub a going over with a wire brush and/or sandpaper and carefully apply copper grease to that area and that area only (i.e not on the brakes) as if an alloy wheel gets corroded on you're going to have some real fun trying to get it off in future.
HTH mate.
There's only one Andy Morrell, only one Andy Morrell. With a packet of sweets and a cheeky smile, Morell is a paedophile.
allvaux your a star, thats pretty much what i did although i found that taking one mother of a swing at the wheel gets it off rather than just randomly hitting it lmao
meh, im ok...want a vauxhall that i cant bloody find but other than that im ok lmao![]()
benn - sorry dude i forgot to take pics...been busy all day![]()
Again using axle stands I've found before a good kicking of the tyre at the top and the bottom of the wheel (steel capped boots only!) from outside of the car can help quite a bit. Axle stands in case you manage to rock it off the jack. The good thing is if you don't want the steel wheels than you can knock the crap out of them with a decent lump hammer.
lets just say that 3 of these steelies will most likely weighed in now lmao
