After the second respray on my bumper it is finally starting to peel. Has lasted much much longer then the 1st respray I did.
I want to re-do it again but I want it to be the final time. The last time I did it I prepared the bumper properly:
Washed and cleaned
Using fine wet n dry to rub it down
Bumper prep used to remove grease and dust
coats of Plastic primer
Then coats of metallic paint
Then laquer
I spent pleanty of time and effort on the prep but it still eventually started to peel. When I did my brothers bumper on his Cav I spent much less time on it just clened the bumper and sprayed paint and its perfect looks like its never been sprayed, stayed on there no problems.
Is it the type of plastic they have used on the Nova MK1 bumper that isnt helping or am I doing sonmething wrong?
Also whats the best type of filler to use on the bumper to sort some scratches out?
Thanx
