The other day i broke one of the vents (heater blowers) on my 1996 Corsa B. The one i broke was the right blower of the two that are in the centre above the heater controls.
I was wondering how would i take the vent out to replace it?
They are held in with pins at each side and are very similar to some toilet roll holders. If you place a large flat bladed screwdriver, or a steel ruler down one side, you should be able to lever it out quite easily. Just do it in reverse to replace it, but once you have it out, you will be able to see how it replaces.
Cheers for the help guys. I managed to do it in the end. I found it easiest if u point the vent downwards as much as possible, then slide a screwriver in near the top, then grab the edge with your fingers and pull. Came out very easily with that technique.
Beanz
