tyre question
Results 1 to 13 of 13
Thread: tyre question
    Feb 2007
    Mansfield
    Mk3 Astra PH2
    tyre question
    i have a mk3 astra 1.4 16v ecotek
    it has what i assume are factory alloys as they have vauxhall logos on them see pic below
    tyre size is 195/55/15
    what pressure should they be inflated to
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    No idea of the exact figures, but I'd be putting them all to 32psi...ish.
    May 2003
    Cheltenham
    a van
    I agree with jack, otherwise check your cars manual, it should have them in there
    back on the roads at last!
    Oct 2005
    Benn's garage
    hitler's taxi
    isnt there a note on the inside of your petrol cap or on the little plate where the drivers door is???
    Feb 2007
    Mansfield
    Mk3 Astra PH2
    not sure i havent looked yet lol it was dark
    Oct 2005
    Benn's garage
    hitler's taxi
    lol
    there should be a sticker or something, if not then 32-33 psi will be fine (haynes manual says for 195/50/15 it should be 33 front and 30 rear - just as a reference)
    Mar 2007
    manchester
    most tyres iv come across has had it on the side wall!
    Feb 2007
    Mansfield
    Mk3 Astra PH2
    max pressure yes but not the pressure to run surly
    also can n e 1 tell me if the alloys i have are standard
    Dec 2005
    UK
    Yes, I'm 95% sure that they were fitted to Astras as standard.
    Yes, pressure on the sidewall will be maximum pressure, not pressure to run. How does a tyre manufacturer know what car you're going to put the tyres on?
    It'll tell you in your manual or in your Haynes book.
    Mar 2005
    South Wales
    Corsa B
    yes they are standard, have them on mine too will go check the book for exact figures for you now
    for X14XE engine:
    Upto 3 persons:
    Front 31.5
    Rear 27
    Full load:
    Front 31.5
    Rear 34
    Feb 2007
    Mansfield
    Mk3 Astra PH2
    well mine are now set to 32 all round...
    Dec 2005
    UK
    Quote Originally Posted by Ian H View Post
    for X14XE engine:
    Upto 3 persons:
    Front 31.5
    Rear 27
    Full load:
    Front 31.5
    Rear 34
    Bloody hell, I wasn't far off!
    I usually go for half way between no load and full load on the back.
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by phil_GT View Post
    that should be fine
