cavalier dash lights
Results 1 to 4 of 4
Thread: cavalier dash lights
    May 2002
    North East
    MR2 Turbo
    my mate has a cavalier m reg 1995, his light has gone out behind the heater control in the center, ive never touched a cav, anyone know the quickest way to get to them?
    Toyota MR2 - 570HP & 420Ft/Lbs
    Designed & Built BY ^Trickster^
    Tuned By Ryan.G 2 Bar Tuning
    Jun 2000
    Hampshire, UK
    Vectra SRi
    there isnt a easy way to get to them but when you do i advise you rewire them to the clock light as then they will only come on with the lights and not burn out so quickly
    i have had a cav for 3 years and muine have never worked
    May 2001
    West Midlands
    at 8500 rpm
    That bulb is a bit of a bugger to change:
    Remove plastic trim from underneath speedo/clocks to expose heater panel screws.
    Remove clock or trip computer to expose the screws on the other side of the heater panel.
    The panel will now move away from its fixed position, but not very far - about an inch, dont pull the panel out as you may disconnect the heater cables.
    You can just about see the bulb holder (side nearest time clock), reach down with fingers and pull out bulb holder and replace bulb.
    Refit bulb holder and put trim back in place.
    Ps - try not to disconnnect the rear screen switch plug connector at the rear of the heater panel also when you pull heater panel out slightly.
    May 2002
    North East
    MR2 Turbo
    thanx lads, appriciated
