corsa c
Results 1 to 3 of 3
Thread: corsa c
    Aug 2005
    corsa c
    will 17z fit on to my mates corsa c without any problems? if so what would people Recommend depth and width wise?
    cheers
    Oct 2005
    Benn's garage
    hitler's taxi
    hi and welcome to mig...fitting is a matter of PCD, offset, tyre size and how low your car is
    PCD should be = 4x100
    offset should be = between ET38-ET49
    size = dont think it will be smart to go more than 7J wide
    tyre size = 205/40/17 i think
    lowering a car = well that depends on how much you have lowered you car or if your planning to in the future
    Mar 2004
    Andover
    nova xe
    if you wanna pay a bit more for tires pirelli do a 195/40/1 and it helps move the side walls away from the archs but they are 120 each i had them on my nova and it stopped it rubbing, then i grew up a tiny bit and got 15's
    supplier of stainless steel fixings and stainless steel bolts for cam covers - www.sts-fixings.co.uk
