Results 1 to 10 of 10
Thread: Number plate foam.
    Oct 2004
    C:\Earth\Unknown
    Nova
    Number plate foam.
    Dunno if this is the correct section to post but here goes.
    Bought a new set of number plates as mine have cracked and are very loose.
    The boot lid is standard so the plate is in its original place currently screwed in. I want to fix the rear plate via sticky pads which I have (2mm thickness) but I was wondering if there is any foam I can buy to put down where there will be no tape holding the plate. This is so the unbonded arears dont rattle when the sub is on at higher volumes. e.g. my dads Cav SRi hatch has foam in shape of the plate which the plate rests on so you get no rattles.
    Thanx
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    Could you not just use more sticky pads, but not remove the paper bit?
    Banned
    Oct 2005
    ThickFord Shropshire
    a BMW again lol
    Just buy some 2mm thick foam from the market!
    get 2inch wide stuff,
    and put 3lines along the plate...
    wouldnt thinkit would rattle that way...
    Mar 2001
    Torquay
    LC 20VT
    Mine don't rattle,and there metal lmao
    Held on with the above strips
    Mar 2004
    edinburgh
    cavalier turbo
    and put 3 lines along the plate...
    wouldn`t think it would rattle that way...
    thats what i did,not had a rattle since.
    i hate the world
    same.
    Oct 2004
    C:\Earth\Unknown
    Nova
    Oh so the 2mm think sticky pads should be enough to keep it away from the skin of the boot?
    In that case great, can fit em on sooner.
    Thanx for the swift replies
    Mar 2004
    edinburgh
    cavalier turbo
    it`s cheaper to buy a roll than say 4 packs of the pads and will stick better and last longer.
    i hate the world
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    stick dynamat to the back of the plate if you really want NO RATTLES
    mine hasnt rattled since i did mine
