No Seats!
I have took my back seats and i am puting and strut brace accross the back and a half cage but i dont want the rough look on the actual base of the car! What do you reckon i should line it with??
Anything or nothing?
MigWeb Moderator
well you have a few chioces here. you can either scrape / strip all the sound-deadening off and then re-paint it all and have it looking raw - track style.
or, make a frame from batons and cover with a sheet of ply wood then capet over it with a simerlar carpet colour to your exsisting carpets.
personally id do the 1st option.
No seats
thats wat i was going to do i mean your first opinion that is but what about the front, i mean carpet in foot wells behind front seats, and also whats behind the rear standard speaker pods??
MigWeb Moderator
it depends how hardcore track day warrior styled your going. are the front seats being replaced with buckets? you could leave the front carpets in place if your keeping the standard seats (in the corsa gsi yeah?) and the carpet follows under the front seats to the rear footwells (one piece) as for behind standard rear plastics and door cards - theres nothing ! just some strips of thin metal (like ribs so to speak) which the rear cards are clipped into.
ok, well yeah i was going to put buckets in aswell but just leave the carpet down in the front!
What we are planning with mine is to use that spray on foam sh*t, you know the stuff you fill gaps with?? Then sand it to shape, and put a thin layer of glass over it, smooth and paint. Although I aint planning on taking the car to any tracks, its more about looks.
Sounds complicated but should look good, why dont you use perspex instead??
