Right guys I'm wanting to do a rear heated seat conversion in the big Calibra. The rear seat is filled with a foam cushion that I plan to cut grooves into using a soldering iron or more likely a knife-saw. I can then lay elements in it.
Now could I wire these up to a relay? I want a switch where the rear ashtray is, for the people in the back. What sort of current would the elements need?
Any ideas?
