I am going to tint my backlight clusters and my side repeters but the tin of spray i just bought from Halfords says its not road leagal. does anyone have any problems with Mr Plod
Its not how fast u go Its how late u brake
As long as the light shines through thoroughly enough than you should be ok.
Make sure there visible in daylight though when spraying them.
-VXRacing-
12.1 @ 123mph 1/4 Mile
I am only going to put a light coat of smoke tint on , so i shoul be ok then ?
the car is a hatch in metalic dark green with colour coded bumpers , mirrors and spoiler i have also de-badged and de-trimmed it, and lastnight i put an electric sunroof in from a Vectra
Like I said, you should be fine as long as the light is still visible through them in daylight.
-VXRacing-
No probs with the babylon so far. Did mine last summer and haven't had any comments yet. I put at least 7 really thin coats of paint on, then a couple of layers of laquer and it still shows the lights when they're on. Well worth doing for a few quid.
Electric sunroof from a VECTRA!!!!!!!!!!??????????!!!!!!!!!!!!
Did u wire in the auto closure?
If so how?
and I take it the vectra mota fitted no prob's?
WANTED - Bogg Brothers R1 Inlet Manifold for a 20XE...
bit of a jiggle this one here goes:-
the motor circuitboard housing had to have a small amount trimmed from it to miss the bottom of the gutter then it fitted perfect
the wiring goes like this :- the brown from the motor goes wit the brown from the switch and both go to ground, then ALL th other wires go together ( large red , black and the traced red ) in a connector to a feed. I used a new feed from the fusebox but i have heard u can use the one from the light but i didnt think it was man enough, by the way i am an electrician
hope this helps
