Sill damage
Results 1 to 21 of 21
Thread: Sill damage
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Sill damage
    Hi,
    Ive got a small dent/crease in one of my sills (Corsa) its about the size of a 1p piece and is starting to rust.
    How much would I looking at for a repair for this job realistically?
    Thanks
    Andrew
    Apr 2001
    Newquay, Cornwall
    Belmont Sri, pearl w
    you could do it yourself clean the rust up then stick a bit of filler over it smoth it off and spray it up. dent's in the sill won't fail an mot so there is no reason why you can't just fill it in
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Sounds like a good idea, ill sand it down, put some Comma Rust Stop on it, filler then primer and then paint...cool!
    Thanks for the help.
    May 2001
    South East
    Just make sure that you get all of the rust out, otherwise it'll just come back.
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Ill try and put a pic up later, and let you judge whether I should tackle it!!
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Will a new section have to be welded in??
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Anyone?
    May 2001
    South East
    Looks like a bit more work may be involved than originally made out.
    Try and get that sorted if I were you....ie panel beater stylee.
    PS How th fock did that happen?
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Its been like that since I got it...ah well!
    Just havent gotten around to getting it sorted, any ideas on cost?
    Nov 2000
    Reading Berkshire
    Vectra GSi & GTE 16V
    Panel beat a sill??
    Cheaper to have a new one put on I would think.
    MIGWeb User GSi-R's Avatar
    Feb 2002
    Kuopio, Finland
    Oil burner
    You could always replace the whole sill, (thats one of many panels replaced/replacing), thats what im doing, but mines alittle worse.
    Similar sill damage though, looks like the jack has fallen at time point.
    Micky
    Apr 2002
    Liverpool UK
    Corsa B SRi
    That could be an idea, any ideas on cost guys? £100-150?
    Aug 2001
    luton
    astra gte8v Hreg
    drill a hole pull the dent out with a slid hammer
    then get rid of every last bit of rud with a grinder or wire bruch on the old drill
    then fill and paint it then wack in some side skirt off a gte on it theres plenty about as looking at the pick they will cover the spot up. son neat bother spraying it can use a bush and tin of hammer right
    that will be the cheapest way with out adding the skirts you need to pay out for a spray job on it
    looks like some ones jaked it there
    my gte was the same when i took the skirts off
    when i strarted the respray
    bet it was a woman with flat befor i had it.
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Its a Corsa so Im not sure if GTE skirts will fit
    The car has had a couple of women owners before me
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Would anyone like to hesitiate a guess of cost of new replacement sill + fitting + spraying?
    Sounds like a lotta dosh.
    Feb 2002
    Kuopio, Finland
    Oil burner
    i understand you have a corsa not a cav, but heres an example.
    Theres a local Body panel supplier near me thats quite cheap.
    Replacment arches for a Cav £10. inc vat
    Front Wings £20. inc vat.
    Sills £18 inc vat.
    At a guess, going on previous cars I have owned your proberly looking at around £60-£100 fitting, and then £40-£70 to have them sprayed.
    HTH
    Micky
    Apr 2002
    Liverpool UK
    Corsa B SRi
    Sorry for the misunderstanding
    GSI sideskirts may be an idea...
    Do you think its worth getting the whole sill replaced? or just repaired/welded?
    Thanks for the input,
    Andrew
    Feb 2002
    Kuopio, Finland
    Oil burner
    Looking at you pic of your sill, you would be better off repairing it, as its not too bad at all mate.
    Mine on the otherhand is a little worse to say the least
    Micky
    Apr 2002
    Liverpool UK
    Corsa B SRi
    I hate careless car owners, especially ones who have f00ked the sill!
    Ah well, that was one of the reasons I got the price knocked down.
    Aug 2001
    luton
    astra gte8v Hreg
    Andrew
    take no notice of the gte bit , I think im loseing it tonight m8 :-)
    but some kind of skirts would be an option
    it wont cost bugger all to replace it for the sill and welding
    just for the paint
    i would repare it my slf m8 it aint bad at all the gsi skirts mite hide it when fixed
    i did not find some prat had done my astra till i took the skirts off
    May 2001
    South East
    Originally posted by mavvmad
    Panel beat a sill??
    As in 'panel-beater' , body shop, accident repair place, its the same thing Mav.
    Not quite so literal mate.
