Hi i was just wondering if i could lower my mk3 astra 60mm and not rub as i have 17's on it?? cheers![]()
Offset of wheels?
40
Can anyone answer me??
Depends if its 3 or 5 door (5 scrub more) and as said above the offset.
A 5 door cant be lowered 60mm on et37 as rob found out the hard way.
99% tongue in cheek
If it was a ET45 I would have said you'd be fine, but I'm not so sure with a 40I know you certainly wouldn't get away with it on a Mk2, but the arches on the Mk3 are a little more forgiving.
/// GTE 16V CHAMPION TURBO ///
cheers. Its a 5dr. I was thinkin of lowering the front 60mm and the bk 40mm or would it look a bit stupid?![]()
Id try and keep the drop level. I hate "nose heavy" cars. Maybe drop to 16"s with the 60mm drop
Cav Sri (Beast) now sold!
Gutted :(
I had mine on 18s et45, dropped 40mm front, 60mm rear, sat evenly front to back.
No arch mods, no rubbing!
if it don't scrub...... it ain't low enough!!!
Looks a good un that. Did it rub with people in it or not at all?Originally Posted by Astra Sport
Gutted :(
No rubbing at all!Originally Posted by Djw Dave
^love that car looks spot on^
DERKHEAD
^ that car looks really nice. I was thinking or lowering it at the front 60mm instead of 40mm cus the front is slightly higher to strt off with so i thought that it would look fine.Its the offset of my wheels that let me down by being 40 so iam unsure weather it will rub with ppl in the car droped 60mm at the bk.Thanx 4 all of ur help![]()
thanx 4 all of ur help i av decided to go wid da 40mm all round.safe![]()
