DIY single wiper
Results 1 to 10 of 10
Thread: DIY single wiper
    Mar 2002
    kent
    Zafira SRI, Astra Coupe
    DIY single wiper
    Is there a way to make a single wiper, for an astra mk2?
    Maybe using linkages from another Vauxhall?
    I'm not to keen on spending £100 on a kit.
    I did it on a Nova, but i'm not sure about the Astra, any advice please???
    Dec 2001
    Panama 16th April ->
    Vectwa
    on the cav and vectra you can get rid of the passenger side wiper and move the central linkage out by about 20 degrees and bingo, maybe get a bigger wiper, but there ya go, dunno about Nova and Astra
    http://www.broadband-central.co.uk
    For discussion about broadband stuff!!
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    I think the nova is the same as the mk2 in which case you can cut about 8mm out of the T piece and use a 20" wiper blade.
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    May 2002
    Huddersfield
    Killah XE Cav
    [QUOTE]Originally posted by beany
    [B]on the cav and vectra you can get rid of the passenger side wiper and move the central linkage out by about 20 degrees and bingo, maybe get a bigger wiper,
    beany how exactly can u do that to a cav i keen on doin a single wiper conversion to my cav u saiid if u remove the passenger side wiper then ur left with the driver side how exactly do u move the central linkage and dont laugh at me
    wat is a central linkage coz im a novice at wipers..
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    It is easy, buy a 24 inch blade.
    Remove the drivers wiper arm.
    Fit big blade to passenger side and loosen the nut that holds the arm on.
    Move arm to the left so the blade is only just on the screen (like in photo below.)
    Tighten nut and test. Adjust by loosening nut and moving as nessecery.
    should look a bit like this when done
    Veni,Vidi,Scubi
    Dec 2001
    Vectwa
    meant get rid of the drivers side wiper ! keep the central one and do what Trevor said, sorry !
    Apr 2002
    north west
    corsa 2.0 16v
    an idea u could try is use a motor from something like the citroen BX and use that instead, as this will give you the full sweep of your wiper blade. When i had me nova i did the same, but used a fiat uno motor and it worked a treat - just a
    thought
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    thought
    I thought of that, but was not sure if on an Astra there would be sufficent clearance because of the location of the fan motor and housing. I guess the best way would be to go to the breakers yard and toolbox one and give it a try!
    Veni,Vidi,Scubi
    Jan 2002
    Edmonton, Canada
    Kadett GSI 8V Turbo
    There is a nice, step-by-step walk through Here
    Mar 2002
    kent
    Thanks for your help guys!!!!!
    I'll give a go at the weekend.
    Now, what can i do with that scuttle panel????!!!
