Results 1 to 11 of 11
Thread: bump strips!!
    MIGWeb User archer738's Avatar
    Mar 2006
    West Lothian
    corsa SRI CDTI
    Angry bump strips!!
    hey guys,
    I wanted to remove those awful bumpstrips down the side of my mk3astra.
    however when i attempted to remove the one from the front drivers side wing i could see something coming out of the wing into the space behind the bumpstrip? anyone got any ideas as to what this is? a bracket or sumthing i aint got a clue!
    cheers guys
    Why do i prefer my car to the missus. i can get in my car all month..............
    sure all mk3 astra ones are stuck on.....
    Mar 2005
    Ireland
    328ci Coupe
    Quote Originally Posted by Benn
    Agreed.
    Not unless someone before has screwed the metal bit onto the wing
    How far is it off? Try an feel is it an actual hole by stickin your finger in??
    I am The EggMan
    Mar 2006
    West Lothian
    corsa SRI CDTI
    yeh the actual bump strip is just stuck on.
    but when i had it half peeled off i could see what looked like two bolts coming from the wing to a plate that was mounted in the gap behind the bump strip.
    this ones gt me beat il see if i can gt pics at sumpoint
    WILLENHALL
    Vectra 1.8 16v
    what body type is it?sport etc because i never had a problem when i took mine off.
    Mar 2006
    West Lothian
    corsa SRI CDTI
    same body type as above, as i said ive nt heard of anyone else who has had this problem. i mite remove them tomorow to take pics.
    Jun 2004
    Ayrshire
    BMW 525TDS / CLK 500 v8
    prob someone tryed to re attach them badly
    All astras came with the bump strips glued on - so probably someones bodge to get em back on !!!
    Mar 2006
    West Lothian
    corsa SRI CDTI
    good guess baldez, looks like tht is what it was.
    i managed to get them off with a bit of help....
    have to slap the guy who did it........
    Oct 2004
    Liverpool
    If its a 3 door will you sell me the rear passenger side piece of it as mines broke
    Jun 2004
    Ayrshire
    what to do is take it off - check out the damage (if any atall) - and the worst happens just glue em back on with tigerseal / sikaflex ect... until you can get it fixed or pick up a cheap door.
    Oct 2004
    Liverpool
    If you was talkin to me bladez, then its not possible because its no good the actual strip, its got a gouge out of it right across it and is cracked off at the end...
