Results 1 to 8 of 8
Thread: gearknob troubles (corsa b)
    Oct 2004
    Edinburgh
    Astra coupe
    just bought an aftermarket gear knob and handbrake lever for my corsa b, think im right in saying i'll have to hacksaw the old handbrake lever off but not too sure on the gearknob, i pulled off the old gear know but just the rubber part, im no left with a yellow plastic cover, do i hacksaw this off too? the gearknob just slides on with grub screws. thanks for anyhelp.
    Oct 2004
    Edinburgh
    Astra coupe
    bttt
    Oct 2004
    Edinburgh
    Astra coupe
    bttt
    Sep 2005
    liverpool
    Signum 1.9 CDTI
    i thought on vaux gearknobs you have to drill down the middle after you have removed the top cap?
    I used to be indecisive but now I am not quite sure
    Oct 2004
    Edinburgh
    Astra coupe
    not sure tbh. looks as if the yellow part needs to come off but not too sure if this will bugger the lift up reverse spring etc. the knob is meant for a vauxhall though although it is aftermarket
    yeah i think you'll have to cut the plastic inner bit off,
    did on my nova,
    have done on a cally,
    Oct 2004
    Edinburgh
    Astra coupe
    managed to get it done, cut off the plastic part,i drilled and tapped a thread down the middle of gearknob as it unscrewd in half and it cant wobbling with just one screw in the middle,it feels and looks perfect now, thanks for your help mudcow007 and benn
    Sep 2005
    liverpool
    Signum 1.9 CDTI
    no problemo squire
