I'm going to attempt a minor repair on the rear arches intime for the Retro car show next weekend. The corrosion is only light besides one area at the bottom of the rear passanger arch.
The rust has just started to come through a few stone chips on the arch lip. I've polished away alot of the discolouration etc but want to stop it as best I can until the body shop sort it out properly.
My plan is to lightly rub the surface rust away with some fine wet and dry, then paint on 3M Rust 'Beater'. I'll then let it go off , sand down and paint with a rattle can so it doesnt look too gash! I'm then going to spray the inner arch etc with WD40 to keep any moisture away.
Does that sound about right?
Will take pics, should start it at the weekend!
