Righty then Iv just bought a new shape astra steering wheel with the multi function controls on but as Iv not received it yet I wondering if it will just fit on or need moding as the same with the air bag plug. Any ideas?
If the spline is the same as the astra 4 it just won't fit. I had to get a Vectra wheel which does. Has the steering controls, but not yet got them working.
For sale, Calibra bits. Two Stainless exhausts. One stainless decat. Airbag. Lots of bits lying around.
pm me
Mutli controls probably won't work but if you can find a wiring diagram im sure you could propably come up with some way of bodging it.
There is a wiring diagram for the vectra wheel to a cally on cavweb. Check the splines though. I still have an Astra 4 wheel that I bought, and need to sell on.
pm me
How much diferace is the between the mark4 an 5 and as im a welder could I cut the splined area off and weld it on
I don't know about the 5. If the splines are not the same as yours, you'll need to weld the cally spline in.
pm me
sounds easy enough I could get another cally colum for £10 wile I'm doing the work but how much will a Astra mark 4 or 5 be second hand.
Will be a good mod though I bet I will be the only 1 or 1 of very few
I would think the only one with a mark 5. I have heard of a mark 4 being fitted which must have been welded.
pm me
Its getting hold of a mark 5 colum though
Vauxhall may be able to tell you if it is the same as the mark 4. Quite possibly.
pm me
Good idea
pm me
