gte bumper
Results 1 to 7 of 7
Thread: gte bumper
    Apr 2002
    Oxford
    Astra GTE 16v
    gte bumper
    Can anyone tell me how you get the bumper of?
    is it the two nuts on top of the fog lights?
    thanxs
    Aug 2001
    Nr Bath
    GTE. Rebuilds:Kadett
    Off the top of my head...
    Three screws over the top of the grill, the two 13mm bolts above the fogs.
    When the screws and bolts are out pull the bumper forwards off the bumper guides on the side.
    In a haynes manual style... Fitting is the reverse of removal
    MK2_ASTRA_SXI
    Guest
    which bumper u on about,
    the front bumper has two bolts kinda inside the front wheel arches towards the front under the lights there 13mm nuts, and ull have to take off the three screws which hold the grill part on.
    the back bumper u have to open the boot and towards the rear lights part of the boot there will be two kinda triangles that have another two bolts on one either side of the car undo these and pull the bumper off
    hope this helps and sorry if its a bit hard to understand
    Apr 2001
    Newquay, Cornwall
    Belmont Sri, pearl w
    spray some stuff on the bolts first coz it's a bugger if they snap as i found out lmao
    Apr 2001
    Norwich
    M3, 200sx, RWD Nova
    What I want to know is why did they make it 10 times harder to get a Nova bumper off than an Astra? makes no sense??
    Simps
    May 2002
    liverpool
    Zafira VXR STAGE 2
    gdsb help me
    help me
    Im a Daddy Wahoooo
    lincoln
    Leon Cupra R 225
    anyone wanna white sri front bumper with two of the two studs sheared off?????
    anyone??
    thought not!
