Results 1 to 4 of 4
Thread: Astra Wing, Headlight Question
    Oct 2002
    boston, lincs
    MK1 GTE :)
    I need another wing, clear indicator and headlight for my astra after a small bump , its a mk3 astra with the v grille i presume its a phase 2 can any one tell me if a front wing, indicator and headlight is the same as a phase 1.
    cheers, Rob
    Jun 2004
    Ayrshire
    BMW 525TDS / CLK 500 v8
    The wing and indicator are the same - the only diffrence is the headlight angle where it meets the grill.
    So you can use the phase 1 wing and indicator - and get a phase 2 headlight is your best bet
    The phase 1 headlight will fit but it will not be a good one at the grill and will not match up with the grill
    Depends how fussy you are i suppose lol
    Bladez
    Oct 2002
    boston, lincs
    MK1 GTE :)
    Cheers Bladez that helps me out loads.
    thank you.
    cheers, Rob
    Jun 2004
    Ayrshire
    No problem - I had to find out the hard way myself - wee bump in my car and had the same probelm
    Peice of piss to swap over though !!
