Results 1 to 20 of 20
Thread: Cavalier offset?
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Cavalier offset?
    I know the best offset for them is ET49, but what is the smallest you can get away with...
    Got my eyes on a set of ET38's...
    And i only want to fit a set of SRi springs to it, so lowering is not a problem...
    MIGClub Member angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Quote Originally Posted by Disco_Mikey
    I had ET35 on mine (not lowered) and one wheel (rear) just clipped the arch over bumps
    Now have ET 40 and is sweet
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Does anyone know if 38's will be fine, or how about a set of wheels spacers?
    Oct 2005
    lincolnshire
    Vectra
    Should be alright with ET38 m8
    Oct 2005
    lincolnshire
    Vectra
    Check the link out m8. It doesnt list cavalier but does list calibra (same offset)
    http://www.alloyguide.co.uk/Vauxhall.htm
    May 2001
    South Wales
    Nippy Cav Turbo
    et35 ripped my arch linings out ask turbo chris lmao ffsss
    May 2001
    South Wales
    Nippy Cav Turbo
    et40 - et49 is all good but DONT use 215x45x17's lmao use 205x40x17's or 215x40x17's if ur offset is et40 and up
    May 2001
    South Wales
    Nippy Cav Turbo
    u will get tramming
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    I found a thing that says, between an ET of 38, to 44 is only about a quarter of an inch difference, so if i do get 38's and fit a set of spacers, it will bring closer to what it should be, yes?
    And i will be using 205/40's...
    MIGClub Member Jasovanooo's Avatar
    Sep 2004
    Bristol
    stage 5 saab 9-3 se sport
    can 215/45/17s not be used at all then? as i was gonna use them on a set of veccie gsi wheels???
    Xbox Live! = DEATHS UNCLE
    The following words in your search query were ignored because they are too common words: 9000 problem
    Jun 2004
    Ayrshire
    BMW 525TDS / CLK 500 v8
    Right et49 is the idead offset and et38 just clips the arches - So by using spacers you would be bringing the wheel out FURTHER therfore asking for trouble as your wheels will sit out the arch.
    Ideally if you have et38 wheels you would want the wheel machined BACK to et 49 to give yourself some room in the arch.
    Or have i just lost the plot ????
    Oct 2004
    C:\Earth\Unknown
    Nova
    My Dad has ET38 Fox Rims on 205/50R15's on his 16v SRi. Its only sracped once and that was with 4 in the back going over very high road humps.
    As for normal driving and normal amount of passengers no problems with em
    MIGClub Member Murray's Avatar
    Feb 2005
    Forres, Nr Inverness
    Cavalier, CalibraXE, Nova
    Quote Originally Posted by bladez
    Nope. I want to do that to mine. But I don't know anyone who, would machine the hubs to the offset I need.
    Mar 2005
    South Wales
    Corsa B
    cant you only get them machined within 5mm of the original offset? or something like that so you could only get it to ET 43?
    Feb 2005
    That would be better than ET38. Just need to find someone to do it.
    May 2001
    South Wales
    Nippy Cav Turbo
    tbh u shouldnt get them machined more than 4mm as ur risking sheeeet lmao
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Ah, just spent the last half hour working it all out! Must be the early morning!
    Right, so...
    If you take material away from the hub face, you are increasing the amount of "wheel backspace", therefore, pushing the offset up?
    Which in turn, is bringing the wheels further towards the centre of the car...
    And that means wheel spacers would make it even worse!
    That make any sense?
    May 2001
    South Wales
    Nippy Cav Turbo
    lmao dude it aint rocky science all the same nice tech ill.
    so here is the saying - Lesser the offset No. more the FLANGE gets it
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Quote Originally Posted by Adam
    It was half 6 in the morning! lmao
    So, ET38's will be OK unless the car is full of fat bar stewards?
    May 2001
    South Wales
    Nippy Cav Turbo
    et38 is gonna be mighty close to ur flamge if not rubin it like a rubba neck
