Results 1 to 6 of 6
Thread: mark 3 dash into mark 2
    Feb 2006
    i have put a mark 3 astra dash hash into a mark 2 astra have it all lined up and mounting bolt holes sorted the only problem is the mark 3 dash seems to be wider than mark 2 and i cant get steering column surround to line up do mark 3 have a longer steering column if so would it fit or is there any other solution
    any help would be appreciated
    also is there any other problems i should look out for
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    have you taken off the top metal part o fthe old dash support?
    Feb 2006
    that wasv one of the first things i took off but the the ignition seems to be sitting to far back towards the bulk head fon the cowling to fit
    Feb 2006
    got it sorted iput a cavalier steering column in instead of the astra one and everything lines up alright
    Dec 2001
    Chelmsford, Essex,
    Is yours the Adjustable column?
    I used the MK2 Cowling and it all fits fine.
    Feb 2006
    sorry for the delay in replying
    no mine was the fixed column but the cav column seems to fit perfect so far
    probably some othert problem will appear later known my luck
    hopefully not
