Astra G front bumper top mount fixing?
Results 1 to 16 of 16
Thread: Astra G front bumper top mount fixing?
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Is this possible? The top mounting on the passenger side is broken. Half of the hole (?!) is missing. If that makes sense. Half of the outer circle that makes the hole is broken off!
    Is this a listed part or is it just part of the bumper? Very annoying problem.
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    Sep 2000
    Falkirk
    A Power Ranger
    Hi,
    I don't really understand what you mean.
    The plastic holes are part of the bumper from what I can remember..
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    Yeah, so they can't be replaces without the whole bumper being replaced. The holes are broken and are not making the bond with the screws.
    Jan 2005
    Hampshire
    '10 3 Series MSport 4dr
    Pictures would help, although it does sound like the bumper itself is causing the problem....
    LMF VAUXHALL - 01858 433599
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    Cant get any at the moment... gimme a sec tho
    Sep 2000
    Falkirk
    A Power Ranger
    aye it does sound like a new bumper
    Sep 2000
    Falkirk
    A Power Ranger
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    This is what has happened to mine too!!! Hmmm. I am not a good DIY'er so never thought of the small washer.
    I will get to my hardware shop and have a looksie.
    Jan 2005
    Hampshire
    So going by that picture, its the star screw that goes up through the arch liner?
    The bumper should hold itself really very well without it, and that just keeps it all in place.
    As has been suggested, a washer should do the job :-)
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    I did try a washer but it kept falling out. I might have to try a few washers together or one thick one.
    Sep 2000
    Falkirk
    A Power Ranger
    I got it totally wrong I thought you meant the 3 top holes on the bumper.
    as Bryon mentioned, it should sit well without that bolt, mine did for a few days lmao
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    Mine has since I got the car but it keeps popping out now.
    rob,
    you could try a speaker style holding clip,wind the screw theu it and in to the std hole on the car side...
    might work,
    star screw
    a wha?
    Sep 2000
    Falkirk
    A Power Ranger
    Quote Originally Posted by Benn
    a what?
    A screw with a torx head
    lol what i thought he ment,was more mick taking,
    Jan 2005
    Hampshire
