Astra Digial CLock
I've seen in Total Vaux there was a nova with a astra clock, temp & date display. I've now got one of these but have no idea how to wire it in. Can any1 help? Also would it be possable to wire in the newer ones? I just really would like the above features.
Also has anyone with the LED washer jets had the crome peeling off?
Regards
Ross
you need the green plug that plugs in the back.
wires are
4 brown = ground
2 black = +12v
blue white?
blue?
black red?
blue black?
black yellow?
blue red = speedo wire
red?
ross, where about in lincs r u?
are u off to the national cruise this saturday?
if so ive organised a convoy from lincoln...
adam
give me your email addy and i will send you the wiring diagram and explanation.... i guess youve got the speed transducer as well i hope!
Re: Astra Digial CLock
Originally posted by rossnunn ...clock, temp & date display... Guys, by the sounds of it he's on about the centre mounted TIME/DATE/TEMP display, not a digi-dash!
clever boy!
now ive read it properly i see what you mean - D'OH!!! nice on Andy...
Hi lads,
Yeh im talking about the time clock's display. Any1 Know the wiring code? or what about the washer jets?
Ta
Ross
Originally posted by Orbital you need the green plug that plugs in the back.
wires are
4 brown = ground
2 black = +12v
blue white?
blue?
black red?
blue black?
black yellow?
red? that should get the digi clock powered up to do the time but not average miles etc.
what about the later ones? Can they also just display the time / date / temp? If so how?
Regards
Ross
soz to hi-jack......will a gsi centre console display (temp, radio station, time, date etc) go into an early mk3 astra?? I know they are the same size, but will I need extra bits at all??
There's no senders as such, but its all gotta be wired into the correct places.
Does any1 know? about the clock? Does any1 know the guy what had his nova in TV?
Originally posted by Mr_PandaPaws soz to hi-jack......will a gsi centre console display (temp, radio station, time, date etc) go into an early mk3 astra?? I know they are the same size, but will I need extra bits at all?? bren put the GSI trip computer in his turbo. it was abit of an effort - he replaced the whole loom in his car to make it easier that adding loads of sensors everywhere.
