Results 1 to 7 of 7
Thread: Cav Ovel grill question???
    Mar 2002
    Brighouse, W.Yorkshi
    Corsa-C 1.2 16v
    Right then all you Cav heads...Nice and easy one...
    If I put an ovel grill on my F reg Cav, will I have to put phase 2 headlamps on aswell???
    Oooh you don't wanna do it like that!!!
    Feb 2002
    my front room
    Obviously you have a mk3 cav.
    If you fit a GSI grille on it will go straight on.
    If you fit a late spec one it will go on, but wont sit completly flush though. Mind you it wont look silly
    Umm..... what to put. Answers on a PM to "Cav boy"
    Mar 2002
    Corsa-C 1.2 16v
    Not flush with what? the headlamps? or the body???
    Are all the clips/holes the same on both early and phase 2 grills?
    I really need some more info B4 getting a late grill...
    BTW/ Yes Mk3 lmao
    Mar 2001
    Torquay
    LC 20VT
    yes same fitting.have you looked at my pictures on my site yet?
    youll find the answers there.
    click below
    Mar 2002
    Corsa-C 1.2 16v
    LEE69...
    So I *DO* need the new headlamps in order for the grill to fit right???
    Aug 2000
    Near Peterborough :(
    STR10K & STR1K
    for it to all line up perfectly, you will need new headlamps AND indicators.
    Daddy Cool
    Drive a Bertone edition Vauxhall? Check out www.vboc.co.uk
    Mar 2002
    Corsa-C 1.2 16v
    A str8 answer...
    Thanks for that Strick, new headlamps and indicators it is then...
