are the fk coilovers height adjustable front and rear or just front adjustable and a set height on the back,because i want some coilovers for rear adjustment mainly,cheers
says on the venom website that they are adjustable (both axles) so i assume that means yes they are front and rear adjustables
been told that the back cant be adjusted by height but i looked on fk's website and they said they was aswell,just mess heads man
right,
the front and coilovers to yes hight and rebound ajustabout,
the rears havea coilover plateform in the spring so you can ajust them,
but its not a coilover unit,
so c an u put in easy term can u lower ur car at the rear or just dampening.
what?
the fronts will have about a 50-100mm drop range,
rear abou and +20-80-mm
Yes you can adjust them.. both height and damping..
The fronts are coilovers, and the spring is seperate on the back..
The spring at the back site on a platform on the beam, and this platform is height adjustable..
what i said....
thanks for the info and sorry for confusion.
they are made buy konie m8 and are verry good my m8 just got some.. would deffo say they are good... you can lower the car back and front,,
