Results 1 to 11 of 11
Thread: BMW Mini Alloys on Corsa ?? HELP
    Sep 2005
    hertfordshire
    Corsa 16v 1995
    I want to fit some BMW Mini alloys on my Corsa B as I have bought them very cheap. They are 5 spoke 16" fitted with 195/55/16 tyres and ET49. I know they will fit but the diameter is 620mm compared to my 14" alloys at 570mm. Will this give me any problems (i.e. bumping over humps, rubbing brake lines etc) and has anyone got pics of this as I don't know how it will look. All input is appreciated. Cheers Mark.
    Oct 2005
    west midlands
    p
    id say them tyres are of a pretty high profile for corsam get some low profs (lol) then it should do. im sure stud fitment is the same, onlky diffrecnce will be or maybe sluggish acceleration due to increase in circumference and higher top speed due to greater circumference however these factors arent that noticeable i suppose, speedo may read innacurate to.
    Apr 2002
    Essex - Colchester
    BMW
    id go for 195 45 16 or 195 50 16 tyres
    MIGWeb User CraigG's Avatar
    Aug 2003
    Scotland
    Audi S4
    is the PCD the same, and the center bore?
    they might be the right offset, but if the bolt holes dont line up(pcd) or the wheel is too small to fit onto the hub(center bore) then they are useless.
    ///MIG PERFORMANCE BMWs
    Apr 2002
    Essex - Colchester
    BMW
    yes, the bolt pattern and PCD is the same as a corsa
    Oct 2005
    cymru
    the best car ever!
    bolt pattern and pcd are the same thing, centre bore might be different tho.
    Quote Originally Posted by toj28
    just got to figure out to get it larger as my wife normally does it.
    Apr 2002
    Essex - Colchester
    BMW
    mini bore - 56.1mm
    corsa bore - 56.6mm
    so no... they wont fit... unless you fancy a bit of machining on the inside of the wheels...
    Sep 2005
    hertfordshire
    Corsa 16v 1995
    as the alloys had run flat tyres fitted i have luckily cancelled the ebay transaction. thanks for the info and i think the bore is too small on the alloys so machining would probably be needed. thanks all.
    Apr 2002
    Essex - Colchester
    BMW
    Quote Originally Posted by mark_pt
    whats wrong with that?
    Sep 2005
    hertfordshire
    Corsa 16v 1995
    Quote Originally Posted by JamesMcbride
    the make the ride too hard (i was told by the seller as he fitted them onto a golf) and i didnt want to machine them to fit.
    Nov 2002
    Livingston
    55 profile run flats arent gonna be any harder than 50 or 45 profile tyres that you should be running on a corsa anyway
