Results 1 to 6 of 6
Thread: The black paint on new panels?
    Apr 2005
    Derby
    Way too Fast :-/
    As above. Whats the score for proper prep with this?
    Years ago it was just for storage (iirc) If you sprayed on it after prepping it used to just chip off as it wasn't 'bonded' to the panel properly.
    What do you do now? Someone told me it was an etch primer, just rub it down and spray it up.
    Help!
    Jun 2003
    Luton
    Calibra Turbo
    Yep, its a primer/etch, Just need to buzz it down with P320 and depending on colour you may be able to "wet on wet" it, (apply paint straight after priming - well after its flashed off)
    Oct 2001
    Herts
    Grale, Mustang, 535i
    It is electrocoat. It has good anti rust properties, but it can be very thin so be careful that you don't rub through it when flatting it. If you do then you will need to apply a coat or two of decent etch primer to be safe.
    Mike
    Bishops Stortford
    2 seat 2.2 vxl
    i went through the black stuff on the nova wings when rubbing down, and adding a mild ammount of topstop for dinks, but they did get a nice plentiful coat of high build ontop though and about 3 coats of paint lol.
    http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
    Fixed broken gearbox calc :)
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    It depends on the quality of the panels. On cheap panels it is just a protective coat and must be removed and a high zinc etching primer applied.
    Veni,Vidi,Scubi
    Sep 2005
    bmena
    corsa
    its bullet proof primer, the best ull get. only thing is when u flat it down u rub thru and then thats where u have to etch prime the bare metal, and then wet on wet the panel. its the best primer available tho.
