Results 1 to 9 of 9
Thread: How should i fit my side skirts?
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    My cavalier SRi sideskirts came today, and they seem to be missing an end cap.
    Can someone just confirm that there should be an end cap supplied with these?
    Anyway, Even if they are slightly too long, I can always trim them an inch or so which isnt a problem.
    How should i go about fitting them?
    Actually how to bond them onto the car
    John
    Astra Coupe 2.2 16v
    Jul 2005
    chesterfield
    omega2.5v6/calibra8v
    tiger glue would make them stick well but you will strugle to get the stuff off if you decide to remove them. are they not screwed on?
    May 2005
    york
    bmw e46 323ci
    Are they mk3 cav facelift sri side skirts, if so mine came with clips i offered mine up rivited the clips on and then clipped the skirks on, mine have end caps,3 pieces per side.
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    Im thinking about perhaps screwing them in on the sides, and then applying some sort of glue along the side to stick them.
    I was planning on sourcing an end cap too to help with the mouting
    Astra Coupe 2.2 16v
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    Quote Originally Posted by Vauxfan
    3 pieces per side?!
    Mine have 1 each on the side, and i juts thought there was 1 from the other end missing
    Astra Coupe 2.2 16v
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    where can i get tiger glue from?
    Astra Coupe 2.2 16v
    May 2005
    york
    bmw e46 323ci
    Quote Originally Posted by johnsastra16v
    3 pieces per side?!
    sorry did i put 3, i must have hit the wrong button, i meant 2 per side. a long 1 and then the end piece.
    Jul 2005
    chesterfield
    my local auto supplies shop sells it but its expensive for a tube.
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    Use windscreen bonding adeshive as long as you get a good surface to mount to works fine
