Results 1 to 4 of 4
Thread: Any info on fitting a Storm single wiper ASTRA MK3 please!
    Dec 2004
    bucks
    ASTRA GSI
    Could anyone help?
    Fitted today and it seems to be touching the filter above the blower motor.I'm thinking maybe ive been given the wrong linkage as it seems to big for the space provided in the buckhead.Any info would be brillant its driving me mad!!!!
    Sep 2004
    Wirral
    Wide Astra GSi
    thats a common problem on the single wiper kits. mine did exactly the same, and it does the same to the car its now on. never did find a fix for it, i just put up with it, but you could possibly grind away a little of what its hitting or grind away a bit of the linkage.
    Dogsy Inc. building mad cars at home since 1997
    MSN - dogsymark@aol.com
    Aug 2001
    i had the same problem on my Cav Gsi - in the end the linkage kept seperating due to the clearance issues and i ended up taking it off and putting it in the loft lmao
    Sep 2000
    Manchester
    XE Corsa
    I had same problem so I ditched the pollen filter for a while.
    BIG mistake, One day I put my hand on the carpet in passenger footwell, It was soaking wet.
    I found the rain was dropping stright through the hole and into the footwell.
    I ditched the linkage in the end.
    Luckily my tastes changed and was bored of the single wiper look anyway.
    I've now reverted back to normal linkage and pollen filter fitted, all is fine now.
