Results 1 to 15 of 15
Thread: Full respray in your own garage? Advice?
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    Could I respray my Calibra in my own garage? It's quite clean and if I did one side at a time, I could have around 5ft of room on each side of the car to work in.
    Would I need heaters? Any other problems ie ventilation?
    I could clean it all out first and make sure it's dust free by watering the floor.
    Jan 2003
    north east
    benz sec /pissrat...
    Give it a good hosing down dont just wett the floor wash the top bottom and sides.
    Get plenty of light in there and you could rig up a car rad fan offa car battery charger shooting threw a hole in the wall.(make sure it not pointing towards your naighbours greenhouse or patio.
    Whatever you do make sure you pay good money for a quality face mask designed for modern paint.
    Moderator Gordon Livsey's Avatar
    Apr 2005
    coatbridge
    Vectra c 1.8 SXI
    bugger that mate, your better with an anti static spray booth, cos sure as christ you will end up with loads of tiny imperfections
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by tarmac chewer
    You mean like dust and dirt??
    Jul 2002
    Leamington Spa
    Satsuma Castanet XR4Turbo
    I used to spray in the open air (!). I got pretty good with a pair of tweezers pulling out little bits of hair and insects.
    Fumes linger for hours and hours, even with good ventilation. I've got a lockup for 6 quid a week. Wet the floor to avoid dust rising from breezes from spraying and moving about.
    Apr 2005
    Newport-south wales
    custom chopped CX500
    best advice would probably be to keep the compressor/air warm maybe point a heater at the tank, if you can pick a warm day to do it aswell all the better because it will dry faster minimising crap landing in it. I think keeping it warm minimises orange peel as well? does something else someone on here said once. You can probably wet sand out some particle imperfections (dust etc) once it's dry but if it's taking hours to dry because it's cold and you get hair in it you might have problems.
    use cardboard on the floor when you wet it not just bare floor, soaks up all the water and stays their longer. Get some dust sheets aswell and put them up make your own booth same day you do the spraying I would.
    for all your welshie needs - msn messenger addy sam.barwick@ ntlworld.com
    ~ diiiiiiiirty slaaaaaaarg ~
    Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep
    Sep 2004
    Northants
    astra sport 1.6 16v
    pm paul0 on here, he recently sprayed 2k in his garage, the job came out a treat! he flat and polished any dust out of the paint, and it looks spot on.
    Vauxhall Astra Mk3 Owner's Club
    Apr 2005
    dundee
    nova GTE 1.6i
    Watch out for silicon m8 its a killer when it comes to paint jobs try make sure theres no car parts in your garage as well it could mess your job up badly but from the sounds of things id do it just sand and polish if the imperfections are not to bad.
    Usualy doing what 2PAC was sayingworks its been working for me. Try keeping the room dust free as possible and youl be ok if not youl end up with pits in your paint like small creators where the dust contacts the paint it couses a sank in looking dints in the paint but thats usualy bad dibree.
    Get your self some G3 compund and usualy any minor imperfections can be sanded and polished up.
    If you dont have heaters m8 a good thing would be to leave it to dry for like a week for garentee the paint is solid go back in and do all the finishing once the period is up. if you do happen to polish it to quickly youl notice the sun will couse the shine/reflection to blur.
    May 2004
    Northern Ireland
    1.2 8v corsa
    Im doing this too.
    keep the floor damp, was the whole shed very well,
    im gonna put a heater in the room to keep it a little warmer, for me as well as the paint!
    and also i saw some hwere anti static sheets which drew dust toward them so u hand them on the walls and ceiling and it stays all nice.
    see my thread on "would you ever attempt a respray yourself,"
    will post link up shortly
    Membership has no benfits to me other than a set of stickers...woo hoo and a member only msg board...erm great!
    http://www.danasoft.com/vipersig.jpg
    May 2003
    Belgium
    '90 opel omega
    Note: the above may or may not be entirely correct.
    I wondered why the frisbee was getting bigger, and then it struck me.
    May 2004
    Northern Ireland
    1.2 8v corsa
    thats the link!
    theres a lott good info in that thread
    Bishops Stortford
    2 seat 2.2 vxl
    i sprayed in a not so clean room with a dry floor, the bigges problem was moths lol never mind. The finish is good enough for me but its not a concourse finish.
    http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
    Fixed broken gearbox calc :)
    Mar 2004
    North Wales
    Astra Mk3 / Golf GTI
    Someone i know uses an old polytunnel to spray. He gets geat results sice it's clean, well lit and warm there, but ventelation is a problem.
    Mar 2004
    Nottingham
    Ventora & Yanks
    be careful using heaters and home made extractors, any spark while spraying can cause a huuuuge fireball.... Best just to use natural ventialtion (ie doors / windows open) unless you have the proper stuff.
    You can get static sheets to put up on the walls to help keep dust off.
    I've sprayed on the drive and even in the street! Most insects polish out dead easy without leaving a mark. Dust is harder as it can leave little pits or cause scratches.
    May 2004
    Northern Ireland
    1.2 8v corsa
    im guessing a gas heater (flame) wouldnt be the best. and then u have the blower heater which could be worse as it could blow dust.
    u can get those electric radiators which would be good!
