mk4 astra side repeaters onto nova?
are they the same fitment ?
cheers
get them from Vauxhall - only 2 quid each.
cut the clips off and stick them on with double sided tape.
easy.
get the bulb holders 2 from vaux (2 quid also) they make the job a million times tidyer, then some small crimps (red)
remove the pants orange nasty thingys by squeezin 2 clip in the inside of the wing, top and bottom of bulb holder, (ull need small hands) and lever with a flat blade screw driver on the front of the wing, put masking tape on the wing 2 protect the paint from the screw driver.
cut the cables close 2 the holder, more cable the better, then crimp the ends (2person job 1 holds the cable while the other crimps its that or have 3 hands lol) and remember them cables r live so dont touch them 2gether or the bodywork. if u do = popped fuse
then attach crimps 2 the mk4 bulb holder. i had 2 use some long nose pilers. and make sure connection is tight, give it a light tug!
remove bulbs from the nova bulb holders, lightly with a pair of piles worked 4 me
pop bulb in and test
cut clips off the back of the lens (leaving the round peg)
attach lens 2 holder
u may have 2 attach tape 2 the back but i didnt need 2
poke assy through hole in wing
test again
job done
"poke assy through hole in wing"
Sounds painful lmao
