Hi, I want to fit 13" RFX Revolution wheels to my standard '95 SRi 1.4 16v. Will they go over the brake calipers. I need the smaller wheels for better acceleration!
Fancy a brew?
bump?
Fancy a brew?
its my understanding that RFX2's will clear the astra 256*24mm brakes, and the RFX1's wont but they should both clear the 236mm corsa brakes.
look on usedrallyspares or what ever its called then email one of the sellers of them.....
http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
Fixed broken gearbox calc :)
What tyres are you planning on using and what is std?
Mike
planning on using rally tyres (175/65 x 13) as these are suitable for the road rallying I do. The standard car runs on 14" wheels.
Fancy a brew?
Sorry, I should have been clearer - what size are the std tyres?
Mike
14"s will just clear 256's.
14's only just clear 256 brakes.
13's just about cover 236's![]()
My 256s (soon to be binned) behind 14" steelies -
Sorry if I have confused you all: I have standard Corsa SRi brakes (not sure what size these are, I will measure them tomorrow) And I want to fit 13" wheels.
Fancy a brew?
