question ?????
Results 1 to 5 of 5
Thread: question ?????
    MIGWeb User TomH's Avatar
    Cheshire
    MK5 Astra 888
    question ?????
    my car has black door handles same as vectra ones and is going in for a spray soon, can i just get another one from the rear doors and put it on my front passanger side and get rid of the lock or are they different fittings ?
    TA
    Tom
    lee may
    Guest
    Yes you can. I have put rear vectra handles on my cav all round. Just make sure you get the backing plate with it (Or you can redrill your ones).
    Cheshire
    MK5 Astra 888
    backing plate ? will i need one of them becuase i am removing the locking system ??
    Kent
    Cav SRi 8v
    Tom,
    U can use the existing backing plate from the front passenger side door handle.
    U will need to remove the key barrel from the backing plate, when I did this on my Cavvy the holes lined up perfect so NO drilling required.
    Hope this helps
    Pete.
    WANTED - Bogg Brothers R1 Inlet Manifold for a 20XE...
    Cheshire
    MK5 Astra 888
    cheers guys, ill get me one tomoz and give it a try
