Results 1 to 6 of 6
Thread: Will alloys fit on nova?
    fix
    fix is offline
    Mar 2005
    Bradford
    Cavalier SRI
    Hi I've got a Nova SR 1.4 and I'm wanting some new alloys, the ones on it are 15" and are offset et49, the ones im wanting to buy are 15" et42. will they fit?
    Thanks
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    Yea should do
    fix
    fix is offline
    Mar 2005
    Bradford
    Cavalier SRI
    ok m8 ill give em a go cheers
    Jun 2005
    sheffield
    hi mate year 84> pcd 4*100 Offset 35 to 45 Bore 56.6 i hope this helps.
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    They might rub a bit with a 42 offset. It'll depend on the width of the wheels and what size tyres you're using. 6" wide with 185 tyres should be ok, 6.5/7" wide with 195 tyres and you'll more than likely have to start work on the return lips on the rear arches.
    fix
    fix is offline
    Mar 2005
    Bradford
    Cavalier SRI
    Ok I'll give em a go, just pray they dont rub
