Results 1 to 8 of 8
Thread: replacing rear arches
    May 2004
    Bournemouth, Dorset
    Pug 205GTI Yamaha R6
    been and got my Joggler
    i've read alot on doing this your self
    Joggler laps the panel.
    It presses a section from the edge away from the edge so it goes from this
    to this
    Then you put the new section on the recessed bit and weld away.
    When welding it on do i spot weld it by putting hole in the new arch panel and spotting to the resesed bit the fill the gap
    OR
    do i weld along the whole lap and grind back and not fill
    ANYHELP WOULD BE GREATFULLY RECIEVED BECAUSE I NEED TO ACT FAST BECAUSE IM GETTING MOVED OUT OF MY WORKSHOP VERY SOON LIKE IN A MONTH AND I STILL NEED TO FILL REST OF CAR AND SPRAY IT
    THANKS TIM
    MK3 Cavalier Breaking, Tinted windows, 18" alloys, 60mm Suspension Kit, Leather, Rear E/W, E/SR, EBC discs, Braided Hoses, Turbo Dash, S/S & Titanium Exhaust, Sparco fuel Cap, Combat Kit http://www.migweb.co.uk/forums/vauxh...ml#post2790995
    May 2004
    Bournemouth, Dorset
    anyone
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    For strength, it'd be best to weld it all the way round.
    Though you could put a few holes in it first to spot it, to hold it in place then weld round after if you wanted.
    May 2004
    Bournemouth, Dorset
    so better to weld right round then grind back rather than just spot and fill
    Oct 2000
    Sunny Milton Keynes
    Bmw 3 series
    Yep.
    May 2004
    Bournemouth, Dorset
    you will see in the pic below i cut below the line it ruffley 7.5mm lower down to allow me to get the joggler in to create the lap joint.
    Once completley cut out you can now lap the panels and spot it on just to hold it there ready for seam welding all the way along - ignore the pen marks on the arch panel i was going to join it ther but its much easier to fill a straight line than a curve
    i was really pleased with the overal fitment of the arch lined up almost perfect.
    ive since started to do the same on the otherside as you can see in the photo the other side is a bit more rusty
    And finally a half decent pic of the fitment of the front lights
    MIGWeb User neil105's Avatar
    Oct 2004
    cullen NE scotland
    astra gte turbo
    Smile
    spot it first to avoid distortion
    May 2004
    Bournemouth, Dorset
    I Did Spotted It In 5 Places Ready To Seam Weld It
