Results 1 to 3 of 3
Thread: Astra G Headlights???
    Dec 2004
    Dumbarton,Scotland
    Astra G Sxi 2002
    Hi there
    Was wondering if anyone knew if you can separate the headlight of an Astra G?
    The problem is that i got a couple of parts of the car sprayed and some how the dust of the paint has managed to get into the headlight on the inside in front of the indicator lens
    Personaly i think it is a sealed unit but anyone`s help would be much appreciated
    Thanks
    Gordy
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Yeah. They are not the easiest to dismantle but it can be done. I would maybe just go get some tinted new ones or maybe even the angel eyes though rather than pull them apart.
    There's a rubber ring round the light unit and then they are bonded together under that.
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    COO
    COO is offline
    MIGClub Member COO's Avatar
    May 2002
    Fife
    Astras: VXR/DTi Van
    You have to stick on the oven, low temperature to heat up the bonded bit, then prise apart gently.
    "It is better to fail in originality than to succeed in imitation." - Herman Melville
